Tools to help your blog content generation
Creating content regularly can be mentally draining. If you are a digital marketer, there are a lot of tools to help you do your never-ending content creation task.
If you are eyeing to do blog content generation, get the help of available tools as much as you can and make things easier for you.
What is blog content generation?
Blog content generation is automatically creating content for your blog, and perhaps, even having it posted afterwards. It means having your blog updated, with less effort and time from you. And of course, you need a software called blog content generator to make that possible.
However, automating everything does not output quality content, thus, can displease the search engines; and Google may even penalize your website for trash content.
To make sure this does not happen, you have to put some human touches on your blog content generation, but you do not need to do it without any help.
There are a lot of tools that can aid you create content in a matter of minutes. Check for the following:
Keyword generator
Tired of thinking of a keyword? Use a keyword generator. It provides you suggestions for your SEO campaign.
Topic generator
The topic generator gives topic suggestions. It is ideal when you run out of ideas on what to write about. Run a topic generator, enter your keyword and the software will come up with topic suggestions.
While some tools can only accept one keyword for a topic, others can process, say, three keywords at one.
Also, other tools can accept more than one keyword. They can even output topics in categories, making it easier and convenient for you as they are already organized.
Spinner
Article spinning is to create multiple versions of an article so the search engines see them as unique. Doing so usually takes a tool called article spinner.
This is one of the SEO ways which can either be black hat, if you generate junk articles; or white hat, when your output articles are truly valuable and unique.
In between, this method can also be gray hat because it cannot be black or white, meaning, your articles are unique and look decent. It cannot be white hat too, because the reader does not get any additional information from your article, since it just another version of the original one.
Proofreader
While editing is a detailed review of a document, modifying it to enhance smooth flow, language accuracy, overall readability, as well as, checking grammar and spelling; proofreading is correcting spelling, typo and grammatical errors.
When you do proofreading using a proofreader, make sure you already edited the document carefully to ensure that your document gets “quality assurance.”
Plagiarism checker
The Web makes it easier to copy other people’s works, hence, the need to check it for plagiarism. Plagiarism is when the writer copies the ideas of another writer and calls the work his own. Copyright laws protect the writers’ work as their property.
When you are using a spinner, it is important to have your work undergo a plagiarism checker. Writers who write for online publication typically make sure they run a plagiarism checker to play safe.
The next time you think about blog content generation, cheer up, for there are available tools to help you every step of the way.
Photo courtesy of Bernadette van Hellenberg Hubar – Flickr
