How to increase the speed of the Article Creator
If you want to scrape more content and process more keywords faster, the first way is to increase the number of ‘max parallel tasks’.
You can find this in the settings menu:
Set the textbox to a number from 1 – 10.
The higher the number, the more tasks can be run in parallel.
However please be mindful of the following:
  • You increase the frequency of Google captcha requests
  • You should be using proxies
  • You increase the memory load on your PC. Depending on the OS you could crash SCM, which leads to the UI of SCM going entirely white.
SCM crashed?
On Windows Server, SCM is likely to crash when running more than 5 tasks at the same time.
Try only starting one task every 1 hour to see the safe limit before errors.
On a modern Windows 10/11 OS SCM runs up to 10 threads without issues.
