My content task folders are missing after upgrade
This problem can occur if you are upgrading from an older to newer version of SEO Content Machine.
Problem
You will have the following problems:
If you upgrade SEO Content Machine and all your settings have been lost and the content task folder pane is empty.
You may also have lost all your custom sources configurations
Solution
Navigate to your username local app data folder.
Type the following into windows explorer.  %UserProfile%\AppData\Local
You will see 2 folders.
  • Satin_Blue
  • SEO_Content_Machine
You need to navigate into Satin_Blue folder and find the user.config file and copy it into the SEO_Content_Machine folder
Once you re-start SCM your old settings will be restored.
Need a content generator?
Try out SEO Content Machine free for 5 days.
privacy We value your privacy and would never spam you
