How exactly does a content generator work? I walkthrough and answer some basic questions for you.
Is it possible to get a unique spun article?
Yes it is. This is how content generator works.
- Find articles using Google
- Download found articles to hard drive
- Re-write aka spin the articles using a free spinner ‘soft-spin' or by buying a paid spinner like WordAi
- Spun content can be used to create new articles.
Just scraping content from the web, means content is not unique.
You must use a re-writer/spinner to make the content more unique.
Can I get a spinned unique article in french/german/other language?
Yes it is possible to, as long as you can find a spinner that supports your language.
Supported languages are:
- Spanish (eSpinner.net)
- French (www.articlespinner.fr)
- SpinnerChief ( many other languages see here -> language list)
If you know how to create your own thesaurus using word|syn1|syn2 plain text file, you can even replace soft-spin with your own custom language thesaurus.
Do I have to manually spin?
No, unless you want to. SCM allows you to spin content automatically. It supports the following spinners.
How do I get unique content?
Unless you write it yourself, you have 2 to use an article re-writer/spinner.
