How to scrape 800 question keywords in 8 minutes
SCM is lacking a nice keyword generation tool.
The best keywords to rank are long tail keywords.
The best long tail keywords that lend themselves to creating content are ‘question keywords’.
Eg, keywords that are used in a question, “What is the best dog training method?” etc
SCM now ships with a Keyword Question scraper.
Find it in scrapers list.
Create a new task for simple UI.
Just type in your main keyword first.
Hit run
SCM will stay on your task but you can see progress of task in bottom.
You can also exit to task list and let tool run.
The keyword question tool will search the following sources.
  1. Google suggest
  2. Reddit
  3. Quora
  4. Google People Also Ask
The tool will run over these sources 3 times, aiming to get 100 keywords every minute.
Why 3 times?
It uses the initial google suggest to find related keywords and uses those back into the search.
Keep an eye on the task in the task log window.
Once the task is finished, open it again to see the keywords.
How to ignore questions
The ignore keywords will remove keywords you don’t want.
Keywords will be crossed out in red, you can use copy button to just copy the left over keywords.
If you want just phrases ending with ‘?’ you can do it with required keywords.
Keywords that don’t match are crossed out in red.
Once again ‘Copy’ button to grab remaining keywords.
The count will also update.
Copied keywords are placed in your clipboard!
