How to automatically insert image links in an article
The mass article creator can be used to automatically insert image links into new or existing articles.
Images are either found via a search or you can even upload your own images.
Links are fully customizable and the image tag can also be customized.
Insert image link can be found under Links in the article creator:
How to add image links
Click add a new link
Find the link insert type dropdown > select insert as image link
Edit your link url and keywords in the top part of the links form
You can see the tag output of the image link inside the properties box below inside Link Location
By default SCM will insert an image link inside a figure tag.
SCM automatically sets the width and randomizes it for you using spintax code.
The width will be 400-409px.
How to set the image source
You will need to edit the image source inside content inserts > images section
Make sure to set insert anywhere to 0-0 to disable normal image inserts as well if you only need image links.
Everything under Image Source is used by the image link inserter.
You have 5 images sources, and 3 image types.
The final output!
The output when run looks like this
