Content Wizard
The content wizard will create articles directly in the folder specified in the article save location.
If you want to have content saved in a new folder, click on the “…” to create a sub folder.
Article Creator
The article creator allows you to use macros to dynamically control the output folder.
Just right click on the textbox of the folder path and you can select form a list of macros.
Don't forget to add the folder “\” slash.
