July 2025 Changelog
July 2025 Changelog
July let your scripts collect the work, not just start it. The API can hand back the article or csv a task produced, and pull a cached page by keyword, so an n8n workflow can run a task and take the output without anyone opening SCM.
Google Maps also got the numbers people actually want out of a listing: the review score, the star breakdown, and the meta description off the business website.
  • Run SCM from n8n or your own scripts.
  • Collect local business data from Google Maps.
  • Work in AI Writer in dark theme.
  • Pull pages from web archives.
Your script can collect the output
  • Ask the API for a task's content and get the article or csv back.
  • Fetch a cached page by keyword, so you can reuse what a task already scraped instead of scraping it twice.
  • Url task results are written to the article output folder, which is what makes them downloadable through the API.
  • Copy a task id straight from the task row, so you can paste it into a script without going hunting.
  • The API key parameter is accepted in lower case, which is what n8n sends.
  • There is an n8n link in the help section.
Google Maps returns the numbers you want
  • The review score comes back with the listing.
  • The star breakdown is read from the rating bars, so the counts add up to the total instead of being close to it.
  • The meta description from the business website is collected too.
  • A missing or awkward site logo no longer ends the search early, including when you search by domain.
AI Writer stopped looping
  • Custom site urls no longer loop forever. The task finishes.
  • Question and answer results come back even with the url limit set to zero.
  • In dark theme, the editor background and inserted sentences are readable instead of inverted.
  • Preview text is one size, so lines align, and strikethrough is thick enough to see.
Small things
  • The web archive scraper takes full urls, not just domains, so you can pull back one page rather than a whole site.
  • About me passes your keyword through the API.
The summary above is written for users. The original 20-item developer changelog is preserved below for exact release detail.
August 1, 2025
  • feat: Google maps return review score
  • feat: Add n8n link inside help section
July 26, 2025
  • fix: AI writer, correctly return QnA results even if url limit is set to 0
  • fix: Make strikethrough thicker and more stand out more
  • fix: AI writer preview, make fonts same size so they line up
  • fix: AI writer darkly sentence insert font color inverted
  • fix: AI writer dark theme editor background color fixed
  • fix: AI writer, custom site urls looping endlessly
July 22, 2025
  • feat: Google maps, grab website meta
  • fix: Google maps not scraping website image logo if using domain as keyword
July 21, 2025
  • fix: Google maps website logo causing search to terminate early
July 19, 2025
  • fix: URL task will save results to article output folder so results can be downloaded via api
  • feat: SCM API task/content returns article or csv content from tasks
  • feat: scm api task cache get cache by keyword
  • feat: Copy task id added to task row options
July 17, 2025
  • fix: SCM apikey param n8n dropcase support
  • fix: about me not passing keyword in api
July 16, 2025
  • fix: col error when scraping google maps
July 13, 2025
  • feat: Google map, calc each review star breakdown from progress bars so it matches total review count.
July 2, 2025
  • feat: You can pass in urls instead of domains to the wayback scraper
