October 2026 Changelog
This page lists what changed in SEO Content Machine (SCM) from 1 to 31 October 2026. For what SCM does overall, see the homepage.
Key facts
- Period covered: 1 to 31 October 2026.
- Size of the release: 152 developer changelog entries, listed in full at the bottom of this page.
- Biggest change: Page Pipeline can now write each page with a research agent that maps the ranking pages, researches the facts, hands the writing to a page writer and has a reviewer score the result.
- Other main changes: Claude Code can read and edit every part of an SEO Workspace over MCP, the SEO Workspace and Page Pipeline share ten page templates, the workspace chat runs extra agents in the background, and publishing uses each page's site plan address.
What changed in SEO Content Machine in October 2026?
In October 2026, SEO Content Machine added a page agent to Page Pipeline that researches, writes and reviews each page, and it gave the SEO Workspace and Page Pipeline ten shared page templates that each write their own kind of page. The MCP server grew to cover the whole SEO Workspace, so Claude Code can plan pages and send them to a Page Pipeline. The workspace chat began running background agents, publishing began using site plan addresses, and GPT-6 joined the OpenAI model list. Smaller fixes covered YouTube subtitles, Web Archives, Local Listings, link sets and the Site plan.
Does SEO Content Machine write pages with an AI agent?
Yes. In October 2026, Page Pipeline in SEO Content Machine began writing each page with a research agent. The agent maps the pages that rank for the topic, researches the facts, hands the writing to a separate page writer and has a reviewer score the page.
- The agent keeps revising a page until every review score reaches 8, with at most 4 review rounds.
- Page agents can ask you several questions at once. The Page questions window lists every question in a side tree and ticks the ones you answered.
- Resuming a Page Pipeline continues each stopped page agent where it left off.
- The task log has an agents pill that opens the page agent map and each agent's transcript.
- Agent web searches use the search region of their task, and agent pages always write in the Region & language you set.
- An agent that opens a page behind a bot check reports the check instead of reading it as content.
- Page Pipeline recommends High effort when it writes agent pages.
What page templates does SEO Content Machine have?
In October 2026, SEO Content Machine gave the SEO Workspace and Page Pipeline ten shared page templates, and each template now writes its own kind of page instead of the same article.
- The new Article template picks the page type from each search.
- Page templates list your own skills from the skills folder, with locate and browse buttons. The app's own skills are read-only.
- The template picker lists agent templates first.
- The SEO Workspace Pages menu sets an AI page template on every selected page.
- Page file names include the page template name by default.
Does SEO Content Machine work with Claude Code over MCP?
Yes. In October 2026, the SEO Content Machine MCP server began letting Claude Code read and edit every part of an SEO Workspace and send its pages to a Page Pipeline, the same as the Create pages button.
- Claude Code can set Site plan hubs and links over MCP.
- MCP updates Page Pipeline tasks, sets their AI templates and model, and sets the Business Info, Image, Product Info, Google Maps and Link inserts.
- MCP lists the tasks of one SEO Workspace and can delete AI templates.
- Task results over MCP point to the output files instead of returning their contents.
- Failed web searches and page loads come back as errors instead of results.
- The Local Listings MCP tool creates a draft task instead of starting it.
What can the SEO agent in SEO Content Machine do?
As of October 2026, the SEO Workspace chat in SEO Content Machine can run extra agents in the background, listed in an Agent map, and it runs several tool calls at the same time.
- The chat gets a message when a task it started ends.
- The chat menu switches each MCP server on or off for each workspace. The chat tests an MCP server it adds and loads its tools only when needed.
- The chat says why a skill you saved did not load.
- The chat no longer cuts off long Claude replies, and on Windows it runs shell scripts over 8 KB.
- The app's AI chat saves and restores its sessions and keeps long tool output in files.
Can SEO Content Machine publish to WordPress?
Yes. In October 2026, SEO Content Machine began publishing SEO Workspace pages at their site plan address, as a post or a page, and keeping the URL of a page that is already live.
- Pages written in one Page Pipeline run link each other at their planned WordPress address.
- Rerunning a Page Pipeline updates the page's draft as a new version instead of adding another draft.
- Pages handed from the SEO Workspace read their template and slug when the pipeline runs.
- The WordPress screens now say site instead of blog.
Can SEO Content Machine plan a hub and spoke site?
Yes. In October 2026, the SEO Workspace Site plan in SEO Content Machine began starting a draft from the page bar, marking pages that have a draft, and showing a spinner on pages being created.
- The Create pages button sends only the pages you pick to the Page Pipeline and pre-fills the Business Info name.
- Tidy keeps the order you dragged pages into.
- The Site plan graph copies a high quality image of the whole plan.
- Undo refuses pages changed since the edit, and removes hub pages added by an accept that stopped on a duplicate topic.
- Merging duplicate pages keeps a URL you set by hand, and a page URL fills from Search Console unless you cleared it.
- Pages with fewer than two supporting topics are no longer flagged as weak.
Does SEO Content Machine support GPT-6?
Yes. In October 2026, the OpenAI model list in SEO Content Machine began showing GPT-6 and hiding mini, pro and retiring models.
- The model menu offers an effort choice for DeepInfra and LM Studio reasoning models.
- Claude models retry rate limits and overloads and report refusals.
- Chat and page agents on OpenAI and ChatGPT models load their tools without failing.
- OpenRouter batch models are left out of agent model selection.
How does SEO Content Machine set anchor text for internal links?
In October 2026, link sets in SEO Content Machine Page Pipeline began setting five anchor types by percentage instead of a generic count.
- New link sets start with the default generic anchors.
- Keyword links match whole words instead of landing inside words or other links.
- Pages written in one run link each other at their planned WordPress address.
Can SEO Content Machine pull YouTube captions and local business listings?
Yes. In October 2026, the YouTube Subtitles task in SEO Content Machine began keeping non-Latin caption text and whole words, and the Local Listings rating filter began accepting 0 to find places with no reviews.
- YouTube Subtitles picks the default caption track and says when YouTube is rate limiting or bot checking.
- YouTube search retries a stalled page load in a fresh window.
- Local Listings skips placeholder emails like [email protected].
- Web Archives downloads from web.archive.org instead of being refused.
- Site Crawler applies Ignore links rules to the start URL too.
- Bulk edit uses the task settings form and confirms each change, and task thread counts apply as you change them.
Where can I find earlier SEO Content Machine changelogs?
Every monthly changelog is in the SCM changelog archive. The previous month is the September 2026 Changelog. To try SCM, start a free trial.
The summary above is written for you. The original 152 item developer changelog for October 2026 is preserved below for exact release detail.
October 30, 2026
- fix: the YouTube search now retries a stalled page load in a fresh window instead of failing
October 29, 2026
- fix: the SEO Workspace no longer flags pages with fewer than two supporting topics as weak
- feat: page agents now hand the writing to a separate page writer and review its page
- fix: the questions window no longer blanks answers an agent saved while it was open
- feat: the questions window now lists every question in a side tree that ticks the answered ones
- style: the questions window and brief notes now show each Answer: line in its own colour
- feat: the Local Listings rating filter now accepts 0 to find places with no reviews
October 28, 2026
- fix: the OpenAI model list now shows GPT-6 and hides mini, pro, codex and retiring models
- fix: page agents now stop re-asking answered owner questions and repeating review rounds
- fix: rerunning a Page Pipeline now updates the page's draft as a new version instead of adding one
October 25, 2026
- feat: Show user skills in template selector
- fix: page templates now list every skill in your skills folder instead of only marked ones
- feat: page templates now list your own skills from the skills folder, with locate and browse buttons
October 24, 2026
- feat: page agents now ask several owner questions at once and reminders show the open count
- fix: page agent reviews now stop at 4 rounds and task logs keep their first lines
- fix: closing the app during a Page Pipeline run no longer hangs or shows an error box
- feat: resuming a Page Pipeline now continues each stopped page agent where it left off
October 23, 2026
- feat: task log now shows an agents pill that opens the page agent map and transcripts
- fix: app chat now saves and restores its sessions and keeps long tool output in files
October 21, 2026
- fix: app refresh glitch
October 20, 2026
- style: task log now hides the task folder path so each line shows its detail
- other: agent page reviews now use fewer tokens
- feat: agent pages now map the ranking pages before researching facts
- feat: agent pages now keep revising with one reviewer until every review score reaches 8
- fix: agent progress lines now show what each tool call is working on
- fix: workspace pages with older statuses now show their last published and refreshed dates
- fix: the url finder now resumes correctly when the only finished keyword is a number
- fix: the AI template editor no longer shows an old template's prompt twice
- feat: page file names now include the page template name by default
October 19, 2026
- feat: each Page Pipeline page template now writes its own kind of page instead of the same article
- fix: the page pipeline log now shows file names instead of full paths
- fix: static pages now saves same-named pages to separate files and fails pages with no text
- feat: task results over MCP now point to the output files instead of returning their contents
- fix: chat and page agents on OpenAI and ChatGPT models no longer fail when they load their tools
- feat: the new Article page template now picks the page type from each search
- fix: the Create pages dialog now keeps each row in place when you add or remove a page
- fix: the skills folder now holds only your own skills and the app's skills are read-only
- fix: agent pages and SEO Workspace chat now always write in the Region & language you set
- other: the SEO Workspace chat now loads its publishing steps only when you ask it to publish
- fix: the SEO Workspace chat now says why a skill you saved did not load
- fix: undo now removes hub pages a Site plan accept added before it stopped on a duplicate topic
- style: the Pages tab and Create pages dialog now say hub instead of main page
October 18, 2026
- fix: the template list now shows agent templates by the same short name as the template menu
October 17, 2026
- style: the sidebar menu now shows Page Pipeline as its own item instead of inside Content Pipeline
- feat: the model menu now offers an effort choice for DeepInfra and LM Studio reasoning models
- style: the Page Pipeline effort warning for agent pages now shows only when effort is below high
- fix: sorting the task list by Time now places waiting tasks by their next run time
- other: publish errors in task logs now start with -JSON API again to show which path ran
- feat: publishing an SEO Workspace page now uses its site plan address and keeps a live page's URL
- fix: the Page Pipeline Pages to create list now shows pages sent from the SEO Workspace as a table
- fix: undoing an SEO Workspace page edit no longer reports a conflict when the app tidied the value
- fix: merging duplicate SEO Workspace pages now keeps the URL you set by hand
- feat: the page agent now has one reviewer that scores each page and reads it twice
- fix: the Local Listings MCP tool now creates a draft task instead of starting it
- feat: the SEO Workspace chat now gets a message when a task it started ends
- fix: pages written in one Page Pipeline run now link each other at their planned WordPress address
- fix: the Page Pipeline now searches for the current topic of a workspace page
- fix: the Page Pipeline now skips a workspace page that is gone or has no template and goes on
- fix: a deleted Page Pipeline no longer shows as the run of its SEO Workspace pages
- fix: the SEO Workspace chat now says it can create pages and names the Create pages button
- fix: the SEO Workspace Create pages button now sends only the pages you pick to the Page Pipeline
- fix: agents that open a web page now report a bot check instead of reading the check page
- feat: the SEO Workspace chat and page agents now run several tool calls at the same time
- fix: agents now read the current MCP server settings on every MCP tool call
- feat: agent web searches now use the search region of the task they work for
- feat: the Page Pipeline now recommends High effort when it writes agent pages
- feat: the page agent now researches first and has two fixed reviewers check each page
- feat: tasks that read page files now read .html pages as well as .txt
- fix: an SEO Workspace page URL now fills from Search Console unless you cleared it by hand
- feat: pages handed from the SEO Workspace now read their template and slug when the pipeline runs
- fix: the Page Pipeline token insert now runs only when it is switched on and adds no double space
- fix: the YouTube Subtitles task now keeps non-Latin caption text and picks the default track
- fix: the Web Archives task now downloads from web.archive.org instead of being refused
- other: the WordPress screens now say site instead of blog
October 15, 2026
- feat: the page agent now edits files and counts its reviewers in its token total
- feat: the template picker now lists agent templates first and hides the old Article templates
- feat: the SEO Workspace chat now runs extra agents in the background and lists them in an Agent map
- style: popups in the light theme have a lighter background
- fix: scrollbars and code colours now follow the light theme after a settings change
- fix: the chat session list and header buttons in the SEO Workspace no longer lose their side borders
- style: the chat messages sit 8px in from the left edge of the panel
- feat: the SEO Workspace and Page Pipeline now share ten fixed page templates
October 14, 2026
- feat: the MCP server now sets the Page Pipeline AI templates and model
- feat: the AI chat drawer log now says what each tool step did
- feat: the Page Pipeline can now write each page with a research agent
- feat: the Page Pipeline skips pages with no content and writes the rest
- feat: the MCP server and SEO Workspace chat can now delete AI templates
- style: the task log now shows each long line as its first line
- fix: the SEO Workspace chat on Windows now runs shell scripts over 8 KB
- fix: the SEO Workspace chat no longer cuts off long Claude replies
- fix: the SEO Workspace chat no longer hangs or loses MCP tools when its agent fails to start
- feat: the SEO Workspace chat and AI chat drawer now run their agent on a background thread
October 13, 2026
- fix: the Claude and Claude Code services now retry rate limits and overloads and report refusals
- fix: the Page Pipeline AI templates now insert img-src-base64 images and stop on cancel
- fix: the Page Pipeline AI templates now keep [text] inside macros as text instead of prompts
October 12, 2026
- fix: the Page Pipeline settings now open on the Page source tab that is switched on
- fix: the Site Crawler now applies Ignore links rules to the start URL too
- fix: a task stopped by closing the app now says why instead of a blank reason
- fix: the URL filter now blocks x.com without also blocking sites like dropbox.com
- fix: the Page Pipeline QnA now keeps each answer with its own question instead of shifting them
- fix: the Page Pipeline keyword links now match whole words instead of landing inside words or links
- feat: the Page Pipeline AI templates now read each page keyword's research on its own
October 10, 2026
- feat: the SEO Workspace Site plan now shows a spinner on pages being created
- feat: the MCP server now sends SEO Workspace pages to a Page Pipeline like Create pages
- style: the SEO Workspace page labels now say main page instead of hub
- fix: a new SEO Workspace named with (1) now takes the business name from its brief
- fix: the static pages combined file now lands in the task folder instead of beside it
- feat: the Settings task thread counts now apply as you change them instead of after a restart
- feat: the SEO Workspace Site plan Tidy now keeps your dragged order instead of resetting it
- fix: notification toasts now use the app font size instead of a larger title
- fix: the SEO Workspace Site plan undo now refuses pages changed since the edit
- feat: the SEO Workspace publish now sends site plan pages as a post or page instead of only pages
- feat: the SEO Workspace Site plan now starts a draft from the page bar and marks pages with a draft
- feat: the MCP server now sets SEO Workspace Site plan hubs and links
October 9, 2026
- feat: the MCP server now sets the Page Pipeline Google Maps and Link inserts
- other: the SEO Workspace page selection menu now leaves out Copy pages
- fix: the Page Pipeline list now shows the SEO Workspace button on tasks made before the last update
- fix: tooltips on task list buttons now use the app font
October 8, 2026
- feat: the MCP server now sets the Page Pipeline Image and Product Info inserts through inserts
- feat: the MCP server now sets the Page Pipeline Business Info insert through an inserts list
- other: the SEO Workspace chat now loads task tools only when it needs them
- feat: the MCP server now updates Page Pipeline tasks and lists the tasks of one SEO Workspace
- feat: the Create pages button now pre-fills the Business Info name in each Page Pipeline task
- feat: the SEO Workspace Pages menu now sets an AI page template on every selected page
- style: the draft button on SEO Workspace pages now shows a tooltip
October 7, 2026
- fix: the SEO Workspace chat now describes Find page opportunities correctly
- fix: bulk edit's confirm box now names every changed setting
- feat: bulk edit now uses the task settings form and confirms each change
- fix: the SEO Workspace chat now reads MCP server instructions and large tool results in full
- fix: text boxes in task settings now use the same font size as the rest of the form
October 6, 2026
- fix: opening a task's settings no longer rewrites its files or settings
- fix: dynamic pages empty rules now collect nothing instead of the whole page
October 5, 2026
- feat: the SEO Workspace site plan graph now copies a high quality image of the whole plan
- fix: youtube subtitles now says YouTube is rate limiting or bot checking instead of failing vaguely
- fix: local listings now skips placeholder emails like [email protected] instead of saving them
- fix: youtube subtitles now keep every word whole instead of dropping letters
October 4, 2026
- feat: link sets in Page Pipeline now set five anchor types by percentage instead of a generic count
- fix: new Page Pipeline link sets now start with the default generic anchors
- feat: the SEO Workspace chat menu now switches each MCP server on or off per workspace
- fix: article filenames now drop slashes from titles instead of making extra subfolders
October 3, 2026
- fix: mcp labels
- fix: the MCP server launch now finds npx, node and .cmd tools on Mac and Windows instead of failing
- fix: the MCP settings page now says tools load on the next chat message instead of after a reopen
- style: the MCP servers list in Settings now shows edit and remove buttons instead of a menu
- feat: the SEO Workspace chat now tests MCP servers it adds and loads their tools only when needed
- fix: the MCP server test in Settings now shows a STDIO server's error output instead of a bare error
- feat: the MCP server now lets Claude Code read and edit every part of an SEO Workspace
October 2, 2026
- fix: the MCP server now reports failed web searches and page loads as errors instead of results
- fix: exclude OpenRouter batch models from agent model selection
October 1, 2026
- feat: Youtube via MCP
- style: the Pages table's add-document button now shows a plus that turns blue on hover
- fix: the Site plan Create and Publish buttons now open instead of doing nothing until Pages opens
