November 2024 Changelog
November took a setting away and made things work better for it. You no longer choose between XML-RPC and WP JSON when adding a blog, SCM works out which one the site accepts and uses it. There is a test button next to each blog so you find out before a run, not during one.
SERP API also arrived as another way to get search results, and Article Creator's search settings moved into the tabs where you actually make the content.
  • Add WordPress blogs to SCM and post to them.
  • Bulk create articles by category and upload them.
  • Get blocked scraping Google search results.
  • Keep more than a few AI templates.
SCM works out how to post to your blog
  • The XML-RPC setting is gone. SCM checks the blog and picks XML-RPC or WP JSON itself, so a blog that rejected your posts because the wrong method was selected now just works.
  • A test button in the blog manager tells you whether SCM can reach and post to a site, before you queue a hundred articles at it.
  • Sort your blog list by url or by group when picking where a post goes.
  • Post and page ids are written to the output file separately, so you can match an uploaded article back to the post it became.
Two tasks get a categorised blog filled
  • Import your blogs into Article Creator and generate posts per category, then upload. What used to take a task per category takes two tasks in total.
  • The CSV for WordPress post generation no longer needs a header row.
Another route to search results
  • SERP API is available as an alternative search engine, for when scraping Google directly keeps getting blocked.
  • Search result settings sit inside the content generation tabs, next to the thing they affect, instead of in a separate area.
  • People Also Ask scraping stops quitting early when two checks return the same number of questions, so you get the full set.
  • The Test PAA box accepts a keyword again.
Find the template you want
  • Tag your AI templates and filter by tag, which starts mattering once you have twenty of them.
  • The %scraped_article% warning stops appearing when you are feeding the prompt local files instead of scraped pages.
Small things
  • Locate in the output browser opens the task's own project folder instead of somewhere near it.
  • Choose the Gemini model you want, and Gemini errors are logged with something readable.
  • Google Translate errors, the Dynamic Scraper error when a run finds nothing, and Scrape Owl proxy strings are all fixed.
  • More tooltips.
The summary above is written for users. The original 21-item developer changelog is preserved below for exact release detail.
December 1, 2024
  • other: tooltips
November 27, 2024
  • feat: SERP API added as alternative search engine
November 26, 2024
  • fix: Google translate error
  • feat: article creator, ai template tagging and filtering
November 25, 2024
  • style: article creator ai writer shortened margins
November 23, 2024
  • feat: article creator using %scraped_article% warning not shown if using add local
November 20, 2024
  • fix: Test paa unable to enter keyword
  • feat: Pressing locate in folder output browser, correctly resolves and navigates to the task %project_folder%
  • fix: google paa scraper, not exiting early if the paa item count is the same on multiple checks.
November 19, 2024
  • feat: Reworked article creator search result settings to appear where its needed inside content generation tabs
  • fix: dynamic scraper error when no results available
  • fix: Google gemini error log
November 14, 2024
  • fix: Post uploader test site fix
November 13, 2024
  • feat: upload poster, select blog can sort on blog url and group
  • feat: wp post generate, csv header no longer required.
November 10, 2024
  • feat: Article creator, wp generate blogs import feature https://forum.seocontentmachine.com/t/bulk-create-articles-with-category-and-upload-to-a-blog-using-2-tasks-only/529/5
November 7, 2024
  • feat: Post uploader, save post/page id seperately to output file
November 5, 2024
  • feat: Blog test button added to WP blog manager
  • fix: Removed xmlrpc settings, SCM will auto detect which posting method to use, either xml-rpc or wp-json based on blog details.
November 2, 2024
  • feat: Add model param for google gemini
  • fix: scrape owl proxy string parsing
