April 2026 Changelog
April was the biggest interface month of the year so far, 89 changes, most of them in the two screens you live in. The AI Writer got a Polish tab with a real rewrite workflow, find and replace with a preview before you commit, and click a term to see it highlighted in the editor.
Page Pipeline got the bulk work covered: a new CSV importer, bulk edit across tasks, a table of contents built from your headings, and validation that names the field you missed instead of refusing to save.
  • Edit and polish AI drafts before publishing.
  • Set up Page Pipeline jobs from spreadsheets.
  • Publish to WordPress, by post uploader or XML.
  • Build topic clusters in a specific region or language.
The AI Writer became a place to work
  • The Rewrite tab is now the Polish tab, with a rewrite workflow that fits how you actually edit.
  • Find and replace opens as a proper modal with a preview, so you see what a rule does before it runs.
  • Click a term and it highlights in the editor. No more scanning for the word you just looked up.
  • The add section modal pages through results and filters by text, so it stays fast on long articles.
  • Insert sentence gained sorting and filtering.
  • AI generate settings moved into their own modal, and the Polish tab explains itself when it is empty.
  • Rewrite translate understands HTML, so tags survive the translation.
  • The article preview replaced its find and replace box with the new one.
Page Pipeline handles bulk work
  • A reworked CSV importer takes your spreadsheet without a fight.
  • Bulk edit across tasks, so a change to twenty jobs is one action.
  • A table of contents generates from your headings, under content inserts.
  • Change how many articles a template creates without cloning the template. The template value is the default now, not the law.
  • Insert videos accepts YouTube URLs as well as IDs.
  • Saving a job tells you which fields are invalid instead of failing quietly, and no longer demands an AI template when you are not using one.
  • AI calls can be aborted early, including from the chat drawer mid run.
  • Page Pipeline exports through a webhook, and the URL data source table sorts and filters.
  • The AI template editor inserts a macro at your cursor when you click it, and shows page macros when the job has them.
Publishing tools cleaned up
  • Every posting window is compact and consistent, with a new post uploader interface.
  • Pick the blogs to post to inside the WordPress export tab.
  • The WordPress category field is a single line input, not a box that swallows text.
  • The WP XML generator finishes the job instead of stalling near the end.
  • Publishing tools resize properly, and their checkbox values save.
  • Add a blog from the Page Pipeline WordPress select with a manage blog button.
Clusters, crashes and theme
  • Topic clusters remember the region and language you used last, keep suggestions inside the geography you asked for, and load results automatically.
  • Find and replace works on topic clusters, and PAA problems are warnings now rather than errors that stop the run.
  • The add links step stopped being skipped in cluster prompts.
  • Save all found topics to a file straight from locate data.
  • OpenAI retries on empty JSON and reads status codes properly before giving up.
  • Google search waits for captchas again, and article body macros stopped coming back empty.
  • Welcome instructions on every task, and a Page Flow welcome for topic clusters.
  • Consistent border radius, opaque text highlight in code boxes, fixed light theme contrast in the header, and no more layout shift from the next run time.
The summary above is written for you. The original 89-item developer changelog is preserved below for exact release detail.
May 1, 2026
  • fix: Remove dropdown deprecated youtube search. replace with automatic handle search if query starts with @
  • fix: Page pipeline, remove old youtube search options, add handle search.
  • fix: Recursion error when processing large ai written files
  • feat: Improved UI for content filter modal
April 30, 2026
  • fix: topic cluster PAA errors downgraded to warning only
  • style: Force consistent hover and focus colors for all textarea in app
  • fix: Cron popup stays open even when clicking dropdowns. Also clamp width.
  • feat: page pipeline, wordpress select, add manage blog button so you can add blog.
  • feat: URL data source UI updated. Table supports sorting and filtering.
  • feat: pagepipeline ai calls can be aborted early
  • fix: chat drawer, logs warnings, you can abort mid way.
April 29, 2026
  • feat: pagepipeline, dynamically generated table of contents under content inserts > headings!
  • fix: prism textboxes, text highlight is now opaque. Also fixed some other color problems in both light and dark themes
  • fix: Fix UI lag spikes when bulk editing page pipeline
  • style: consistent app border radius
  • fix: remove drop shadow on colored buttons
  • fix: Page pipeline unable to save if you didn't select ai template, even if using other modes.
  • fix: Page pipeline, report what fields are invalid in popup
  • fix: publish tools are responsive
  • fix: publishing tools incorrect ui width. checkbox values not being saved.
April 28, 2026
  • feat: Article preview box replace find replace box
  • style: page pipeline, insert links. Updated tooltips and labels to be clearer.
  • fix: single slider controls causing react stack errors
  • style: fix image and video bg light theme wrong color
  • fix: article writer, polish, remembers last used rewrite and translate settings
  • style: page pipeline moved region + lang to where it belongs.
  • feat: On app error, show button to get new updates
  • fix: API logins modal height stays within screen height
  • style: Fixed darkly BG being to light on modals and drawers
  • feat: page pipeline, insert videos accept both youtube ids and urls
  • fix: app header now has proper light theme with better contrast on buttons
  • fix: page pipeline run save crash
  • feat: New reworked CSV importer for page pipeline
  • style: Enter API button made into icon button
April 27, 2026
  • fix: AI template editor, clicking on macro will insert it at cursor location.
  • feat: ai template editor, display page macros if available in editor.
  • feat: rewrite translate is html aware
  • feat: ai writer, empty state explainer on polish tab
  • feat: ai writer, rewrite tab is now polish tab and has new rewrite workflow.
  • feat: AI writer, clicking on a term will highlight it in editor
  • feat: ai writer, proper find replace modal with preview
  • feat: AI writer, ai generate settings moved into popup modal
  • feat: Article writer, insert sentence modal has sorting and filtering
  • feat: AI writer, add section modal tweaked, uses pager for performance. integrated text filter.
  • style: Removed incorrect blue border on darkly button active
  • style: Standardized width of input controls to 320px. Makes scanning easier.
  • style: Page pipeline, selected ai templates appear in list instead of hi vis table
  • feat: Pagepipe line has export webhook
April 26, 2026
  • feat: all posting window ui have been adjusted and compact
  • fix: WP XML generator unable to finish due to bug
  • feat: new post uploader ui
  • feat: page pipeline, select blogs to post to inside wordpress export tab (future: make entire posting task automated)
  • fix: wordpress cat text input is only single line now
  • fix: super spin label added for clarity, Tooltip expanded.
  • fix: On app error, show the window controls
April 25, 2026
  • fix: topic cluster, better 960px support
  • feat: Video data shows date filter
  • other: Removed jquery, updated json ld editors in page pipeline to follow theme
  • style: Shrink time display so there is no layout shift when showing next run time
  • fix: Aborting… won't clear if you press stop again.
  • fix: Topic cluster templates using language macro
  • fix: %article_body% was always empty
  • fix: Bing force language and country via mkt
  • fix: If first line is a title or h1 tag, if its multiline, correct fold it back to 1 line to handle edge cases
  • feat: Page pipeline, you can change number of articles created without creating new template. The template value is used as default.
April 23, 2026
  • feat: Add task bulk edit
  • feat: Save all found topics to file, found via 'locate data'
April 22, 2026
  • feat: Welcome instructions for all tasks
April 21, 2026
  • feat: pageflow welcome for topic cluster
April 18, 2026
  • fix: openai better status code parsing to allow retry
  • fix: Remove def sytem prompt from new installs
  • fix: Topic clusters prompts was skipping add links step
  • feat: topic cluster find replace
April 17, 2026
  • fix: Stricter geo fenced suggest results for topic clusters
  • fix: Topic cluster wasn't auto loading results
  • fix: topic cluster remembers last used region/lang
April 13, 2026
  • fix: Ensure output path exists for cluster results when task is started
  • fix: clean text error when using article-body
April 9, 2026
  • fix: cleanText crash
April 8, 2026
  • fix: Log error JSON req for open AI debug
  • fix: Allow open ai to retry on empty json error
April 6, 2026
  • fix: Google scraper wasn't waiting for captchas
  • fix: Possible fix for UI crash for page pipeline
April 5, 2026
  • fix: Swap out chinese tokenizer with another native node
  • fix: Extra checks for Google search
  • fix: When reading articles for WP xml rpc, clean invalid string to fix Worker Error: Invalid character in string.
  • fix: Better handling of json null cleaning before sending to openai
  • fix: Local listings, not forcing language set in task data (was using exiting hl if it existed)
  • fix: Local listings, save to google sheets crash.
