Custom QnA search terms for the Article Creator
The article creator allows you to use keywords to search for both content results and Google Questions and Answers.
If you use a very specific keyword to search for content, it's very possible that you won't get any QnA results as a consequence.
eg: Article keyword is ‘razer moba mouse'
Article Creator
If you want generic QnA about gaming mouse.
Now inside QnA insert…
image 28
There is search string box where you can override the search to be ‘gaming mouse'.
Checking out the task log:
image 29
The article creator does 2 Google searches.
First, to get content results for ‘razer moba mouse'
Finally, to get just QnA results for ‘gaming mouse'
Now you can get different results for both content downloaded and QnA.
Search String options
Default is to use the article keyword.
image 30
The search string also supports the use of article variables eg:
image 31
image 32
or you can type in your own keyword
image 33
Scroll to Top
