June 2026 Changelog
This page lists what changed in SEO Content Machine (SCM) from 1 to 30 June 2026. For what SCM does overall, see the homepage.
Key facts
- Period covered: 1 to 30 June 2026.
- Size of the release: 26 developer changelog entries, listed in full at the bottom of this page.
- Biggest change: the topic cluster chat was rebuilt, with search you can limit to one part of the project.
- Other main changes: contextual internal links inside the article body, better Chinese, Japanese and Korean detection, a redesigned API Logins screen, and thread limits that hold.
What changed in SEO Content Machine in June 2026?
In June 2026, SEO Content Machine rebuilt its topic cluster chat and made topic import more accurate. Page Pipeline learned to place internal links inside the text and to tell Chinese, Japanese and Korean pages apart. The API Logins screen was redesigned, and fixes made task limits, aborts and sign-in more dependable.
Can SEO Content Machine group pages into topic clusters?
Yes. In June 2026, SEO Content Machine rebuilt the topic cluster chat header and split topic search into separate toggles, so you can search one part of the project instead of everywhere.
- Topic import matches pages by URL more strictly and keeps the search intent from Search Console.
- Undo and delete now clear the matching Data tab history.
- The site scan evidence popover is easier to read.
- Pages have a new status, and topic instructions refresh when the prompt is rebuilt.
Can SEO Content Machine add internal links inside the article text?
Yes. Since June 2026, Page Pipeline in SEO Content Machine inserts contextual links into the article body and places them in the paragraph you prefer.
- Page Pipeline no longer writes a page when %title% is empty, and it warns you instead.
- The page parser can find an H1 in meta tags when a template needs it.
- The Page Pipeline progress bar stays visible until the run ends.
Does SEO Content Machine handle Chinese, Japanese and Korean pages?
Yes. In June 2026, SEO Content Machine got better at telling Chinese, Japanese and Korean apart, and it stopped crashing when it split Chinese text into words.
Can SEO Content Machine run many tasks at once without going over the thread limit?
Yes. In June 2026, SEO Content Machine began locking jobs against the concurrency setting, so the thread cap you set holds.
- The abort action stays ready when a task finishes early while it is being aborted.
- Task chains can be cleared.
- Sign-in calls are faster, and the API Logins screen was redesigned.
Where can I find earlier SEO Content Machine changelogs?
Every monthly changelog is in the SCM changelog archive. The previous month is the May 2026 Changelog, and the next is the July 2026 Changelog. To try SCM, start a free trial.
The summary above is written for you. The original 26 item developer changelog for June 2026 is preserved below for exact release detail.
June 22, 2026
- feat: Added new status
June 20, 2026
- fix: tighten URL identity + gsc intent-drop in topic-cluster ingest
- fix: undo/delete now clear Data-tab history; link + fuzzy-match bugs
June 19, 2026
- fix: refresh topic instructions on prompt rebuild
- fix: clarify site scan evidence popover
- feat: split topic search “everywhere” into per-scope toggles
- feat: rebuild topic-cluster chat header
June 16, 2026
- fix: tune topic-cluster chat font sizing and panel chrome
- feat: modernize API login settings
- fix: route Codex LB settings checks
- feat: claude code streaming
- fix: settle stale loading status on session load
- fix: gate job locking on concurrency so thread cap holds
June 14, 2026
- fix: compact no deadlock
June 11, 2026
- feat: claude code, codex added as AI services
June 9, 2026
- fix: abort action stays ready when task finishes early during aborting
June 8, 2026
- fix: ph app icons not aligned
June 5, 2026
- feat: insert links, contextual, preferred paragraph placement.
- fix: insert headings after only 2nd paragraph
June 3, 2026
- fix: Page pipeline prog bar disappeared too early
- fix: Crash when getting chn words. Use node instead.
- fix: Don't write when %title% is empty. Warn.
- fix: better lang detect between chn,jpn,kor
- fix: slow login calls
- fix: chain task, allow clear
June 2, 2026
- fix: parge parser finds h1 in meta tags if required
